hynautic cylinders >
hynautic cylinders
hynautic cylinders
Old 11-28-2009 | 05:44 PM
Default hynautic cylinders
anyone know the cu inch volume of the k-5b cylinders? trying to figure turns end to end with h42-02 helm which is 4.0 cu inch////////////////thanks in advance
johnnyexcal is offline
Old 11-28-2009 | 06:37 PM
Default hydraulic steering
Not sure, but maybe this spreadsheet will help what you're trying to do. I am looking at swapping over to a full hydraulic as well and wanted to figure some system parameters.
The spreadsheet makes some gross assumptions but in a single plane, the math should work. I could do a lot better in ProE.
Randy
bustedbrick is offline
Old 11-28-2009 | 07:32 PM
Randy
file won't let me open / [email protected]
Old 11-28-2009 | 08:49 PM
found it k-5 cyl.=15.9cu inch of volume
so helm is 4.0 cyl. is 15.9 should be equal to 3.98 turns hard lock to hard lock . right?
Old 11-29-2009 | 12:11 PM
Rookie's Avatar
The one you are looking at in th swap shop has 2 cylinders so it would be 8 turns lock to lock.
I am running a hynautic system on my boat right now and it is 8 turns. I don't mind it but I have twins so I can turn by using forward and reverse. On a single that would be a pain in the a$$.
I guess if you just used a single cylinder it would be ok.
Rookie is offline
Old 12-01-2009 | 11:46 AM
The K5s are unbalanced. The volume of the rod takes up some volume on one side. So that number wont be exact.
As was ponited out, 2 cylinder would be about 2X the volume, but it would be a balanced etup, so at least turns to lock would be the same in both directions.
rdoactive is offline
