Question about Volvo Penta 454 >
Old 12-09-2009 | 01:06 PM
Default Question about Volvo Penta 454
I have a Volvo Penta marine 454 engine. The guy I got it from said it was a 1994.That is all I know about it. Can someone tell from the brass # plate year and HP? 4100140606. Thanks Mike.
89 Baja 250 is offline
Old 12-09-2009 | 09:38 PM
Found some info. I think it is a 92 to 93 Volvo penta 740b 454 engine.
Old 12-10-2009 | 12:27 AM
Yes it looks like you are right, Here is what I could find with the serial# 4100140606
Technical data
Engine 740B
Production period 1992-1993
Operation 4-stroke
Cylinder configuration V-8
Bore (in.) 4.25
Stroke (in.) 4
Compression ratio 8:1
Displacement (cu. in.) 454
Power (hp) 330
Max engine speed (rpm) 4400
Boat Tech is offline
Old 12-10-2009 | 07:07 AM
If it is a 92 or 93. Is that a generation 5 block?
Old 12-10-2009 | 07:15 AM
spazboz's Avatar
Is that an automotive distributor?
spazboz is offline
Old 12-10-2009 | 07:52 AM
Yes. It came with engine when I got it.It works fine. But gona change to a marine type.
Old 12-10-2009 | 08:43 AM
it should be a gen V std gm HEI dist. but they work very well if set up correctly, I run a DUI version of that and like it..very simple and reliable...Rob
ezstriper is offline
