Need New Tow Vehicle >
Old 12-23-2009 | 10:21 AM
  #31
Originally Posted by mrfixxall
oh by the I don't see 90% trucks being dodges out there....well maybe sitting on there lots...
Im the midwest,, i live close to indiana where most of the cargo trailers are built..i see that most of the people moving the new trailers are dodge trucks,i see a few chevy's pulling them to but mostly dodge's..
just my o2!
because they are a cheap disposable truck....same reason 99.9% of fleet semi trucks are freightliners...cheap to buy and cheaply made..
Let us know what you decide to buy! I would think right now the dealers would give some pretty hansom rebates and things to move trucks.
boatntrkr is offline
Old 12-23-2009 | 12:27 PM
  #32
Something I forgot to mention...
When I was comparing Chevy, Ford and Dodge back in 2005 I also looked at turning radius. These crew cabs have a long wheel base and I didn't want to feel like I was driving a friggin' bus. Back in 2005 the Chevy had the tightest turning radius by a pretty significant amount if I recall. Not sure how they compare now. Makes a difference working in tight spaces.
4mulafastech is offline
Old 12-23-2009 | 12:42 PM
  #33
as far as I know the 3.73 and 4.10 are only options. I think the 4.10 is a special order generally, but really think twice about going for it, most do not need it. If you drive a 06 or a 07 classic with hte LBZ you will be impressed. As far as fuel additives are concerned, I think it is a good idea. Any diesel truck made before 07 was designed to run on Low Sulfer Deisel(LSD), when they went to Ultra low sulfer diesel(ULSD), the process to remove the sulfer destroyed the lubricity of the diesel. Next time you go to get diesel look at the groung around the pump, when i was a Kid the ground was a big oil slick at the diesel pump, well it is not like that any longer. So I feel the need to add that back, the best product out there is opti-lube XDP. A group of guys on Diesel Place (a forum like this one) all pitched in to test lubricity products, and this one beat them all hands down. Your truck will run quieter too. I like the new body style, and the LMM seems to be a god motor, but I know that mileage is way down due to the active regeneration for the Particulate Filter and because of the EGR.
tx911 is offline
Old 12-23-2009 | 01:25 PM
  #34
tx911,
Good point on the ULSD. Regarding the additive testing, do you know if they tested Diesel Kleen or do you have a link? Thanks.
Old 12-23-2009 | 01:35 PM
  #35
open the pdf on this page
http://www.dieselplace.com/forum/sho...d.php?t=178848
tx911 is offline
Old 12-23-2009 | 04:33 PM
  #36
Default Fixx
Owning a auto repair shop,, i repair more fords then chevys compared to dodge's.. By all means I'm a chevy guy but the last few years on the chevy i have replaces several dash cluster's,FWD encoder motors, on the rear end the backing plates rust out which cause the emergency brake shoes to rattle, you can count on replacing the rear rotors at every brake job,driver side window switch goes out then you have to reprogram the bcm to tell it theirs a new switch installed..i have one customer on several occasions had a service FWD appear in the dash display..Im not knocking chevy but here's some of the problems i had to deal with..As for dodge their built pretty tough, the only issues with the dodges is the front axle and drive shaft ujoint's will need to be replaced between 60,000-70,000 miles but that's it!
just my o2~
FIXX is offline
Old 12-23-2009 | 04:49 PM
  #37
well from all the guys I have talked to and on the diesel truck forums, the cummins engine is great, but unless you get their manual trans, GFL....there auto's have been and still are pretty much junk...and if you do any power adders it's a quick death. all those dodges you see pulling trailers, bet if you look they are mostly manuals...sorry want no part of a manual at this point...
ezstriper is offline
Old 12-23-2009 | 06:17 PM
  #38
I have a late model DMAX (06 LBZ) that is my tow vehicle/daily driver, and I love that truck. It replaced a 1500 Avalanche and even though I liked my Avalanche-I LOVE MY DMAX. Go drive one.......
Old Navy is offline
Old 12-23-2009 | 06:56 PM
  #39
Mr Fixxall
Are you refering to chevy trucks in general, or to diesel trucks? I know the 1/2 ton gas motors have a dash issue covered under a special policy from GM, I think until 70k or 100k, but I have not heard this on the diesel trucks. Laso on the rear ends, I dont know about the 1/2 tons, but the rear end in the Chavy 3/4 ton up is the same AAM axle that dodge uses too and is generally thought to be the best axle going, even better then the dana 60/70 axle.
tx911 is offline
Old 12-23-2009 | 07:00 PM
  #40
Mr Gadgets's Avatar
Charter Member #601
Well Elite,
are you driving a new truck?? Merry Christmas to you, I hope!!
I am loving this thread, learning more than I did in high school!! I will have to wait till I get some money together, but I have a good idea what I want. The Dmax seems like the one that wants me!! I think an 06 will be close to the budget, by the time I get some saved, maybe the price will come down..
Dick
Mr Gadgets is offline
