Bravo outdrive install question >
Old 12-25-2009 | 11:59 AM
Default Bravo outdrive install question
I removed my outdrives to check the bellows, u-joints and engine alignment. All looks great. I will be replacing all the o-ring seals. The manual states to use 92-86166-1 3M brand adhesive on the ones that seal the outdrive housing. ishopmarine dot com says this has been superseded by 9286166Q1 bellows adhesive. I was picturing an aerosol type like 3M Contact 80 (see link). What do you guys recommend? What is the best thing to use for removing the old adhesive? Also, where is the best place to buy all these o-rings and small stuff on-line? Any other tips are appreciated. Thanks.
http://solutions.3m.com/wps/portal/3...glF4GT15FZTJbl
4mulafastech is offline
Old 12-27-2009 | 10:43 AM
Default ttt
Now I know some of you work on your own boats... This is my first outdrive install. How 'bout a little help for the rookie?
Old 12-27-2009 | 11:02 AM
Bam Marine is a good place for the seals. As far as the adheasive wire brush or acetone either way the paint is coming off..
I'd have to say I don't see why the spray adheasive wouldn't work.
Irishtornado is offline
Old 12-27-2009 | 12:54 PM
This stuff works good, Just wait till it get's tacky to put the O rings on, It will not take to long. it's called gasgacinch gasket sealer, And the brush that comes with it makes it easier and cleaner to applly.
http://www.google.com/products?sourc...ed=0CB4QzAMwAg
Boat Tech is offline
Old 12-27-2009 | 01:51 PM
Default Fixx
#m weather strip adhesive works good also,you can get it at your local auto parts..like mentioned acetone works well or non chlorinated brake cleaner works also..Apply with a rag and keep the rag wet with it and it will come off..
FIXX is offline
Old 12-28-2009 | 11:01 AM
On my 2 previous Bravo transom plate intstals I only used a decent quality grease on the main perimeter seal. One boat has been over 20 years with no leaks or problems and the other I sold last spring and it was done 12 years ago. I will be doing another in the spring exactly the same way. As long as transom surface is clean and straight you shouldn't need a sealer.
boatnuts is offline
Old 12-28-2009 | 12:26 PM
Thanks guys. Great info.
Old 12-29-2009 | 06:01 AM
I just use a small amount of RTV...Rob
ezstriper is offline
Old 12-29-2009 | 12:57 PM
seafordguy's Avatar
On those O-rings it is really about holding them in place while you fumble and cuss to put the drive back on.
If you pulled the bellows off USE bellows adhesive to put them back on....
seafordguy is offline
Old 12-29-2009 | 03:44 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I never cared for the Merc method of holding teh o-rings in. The adhesive (weatherstriping adhesive I assumed) was always stiff.
I prefer the o-rings to stay flexible and just use a dab of grease to hold them on. Just reach inside the bellows for a nice amount of grease.
Try not to scratch the paint off if possible while cleaning the old stuff off. Bare aluminum will corrode easy.
US1 Fountain is offline
