Best subwoofers >
Best subwoofers
Best subwoofers
Old 01-02-2010 | 08:12 PM
  #71
jonyb's Avatar
PM'd
jonyb is offline
Old 01-04-2010 | 08:35 AM
  #72
Originally Posted by jonyb
Sounds like a good reason to buy more
Don't expect much from the Bazookas. In fact, don't expect most of them to last a couple months. Several customers have brought those in for install and they didn't last more than a week. The amps in them are junk.
The "good reason" is they are cheap.. Most batteries are the same.. No reason to spend tons of $$$.. they can drain and recharge over and over till they are done.. Interstate makes a quality battery.. And the remans are often a great deal.. They have plenty of AMP/HRS to drive 4 JL Amplifiers for about 4-5 hours at 3/4-100% full volume.. (although to be honest I did not experience one failure all last year from the bats being drained)..
The key is to make sure they have water!!! if not.. ANY fill battery will explode when left on a charger.. (so.. my fault not the battery)..
JohnSchiavarelli is offline
Old 01-04-2010 | 10:10 AM
  #73
jonyb's Avatar
The batteries I use are dry-cell's. Don't have to worry about all that.
jonyb is offline
Old 01-05-2010 | 07:15 PM
  #74
srl520's Avatar
Just a peek at the Subs going in. I will post pictures of this project as it comes together.
JL 12w7's
Attached Thumbnails Best subwoofers-p1020307.jpg   Best subwoofers-p1020308.jpg
srl520 is offline
Old 01-05-2010 | 08:51 PM
  #75
jonyb's Avatar
How much air space is in there? They look tiny, especially with the displacement of the woofers.
jonyb is offline
Old 01-05-2010 | 10:35 PM
  #76
srl520's Avatar
They are a little small. There only1.8 cu/ft. I may have to expand them alittle wider. I don't have much room on the starboard side to go much wider because of the battery switch. Also, I am mounting the amps in the middle.
srl520 is offline
Old 01-06-2010 | 12:10 AM
  #77
jonyb's Avatar
Sealed calls for 1.875 and displacement is .21, so looks like you've got it pretty close, as long as it's completely sealed.
jonyb is offline
Old 01-06-2010 | 04:33 PM
  #78
Strip Poker 388's Avatar
Rob
what about a solar baric style sub? Dont they require less space? 12 inch,box size,cf
Attached Thumbnails Best subwoofers-boat-paint-8-26-09-150-large-.jpg   Best subwoofers-boat-paint-8-26-09-153-large-.jpg   Best subwoofers-boat-paint-8-26-09-159-large-.jpg
Strip Poker 388 is offline
Old 01-07-2010 | 07:15 PM
  #79
jonyb's Avatar
solo-baric, and most woofers these days take the same amount or a little bit more.
jonyb is offline
Old 01-08-2010 | 11:47 PM
  #80
Rob
a 12 1 cubic foot?
