4" stainless - reducers and 45's >
Old 12-26-2009 | 11:01 PM
Default 4" stainless - reducers and 45's
where is the best assortment of already prefabbed stainless reducers and misc. angles, couplers?
thanks,
john
getrdunn is offline
Old 12-28-2009 | 08:12 AM
hoozeyurdaddy's Avatar
try CP Performance, I've got some odd stuff from them before.
larry
hoozeyurdaddy is offline
Old 12-28-2009 | 05:39 PM
larry
Thanks,
John
I did check out there website but perhaps I may need to open there pdf catolog. I know I have seen these available somewhere. I just need to change the angle slightly before exiting the transom rather than spending a ton of money on sending my tails in to have then altered.
getrdunn is offline
Old 12-28-2009 | 08:09 PM
Mbam's Avatar
Offshoreonly Advertiser
There are a bunch out there, but if i just need 1 or 2 pieces I use Mcmaster Carr. Go to www.Mcmaster.com & search for weld tube fittings.
Burns Stainless is also a good source.
Mbam is offline
Old 12-28-2009 | 10:05 PM
If you can't find what you need at the places that Marc suggested, either I or CP Performance can build whatever you want. If you use CP, call CA. and ask for Mike Mays.
Eddie
Young Performance is offline
Old 12-29-2009 | 03:25 PM
never mind... everything you need is already there...
wtfo is offline
