HP500 Valve Springs, which ones? >
Old 01-04-2010 | 10:05 AM
Default HP500 Valve Springs, which ones?
I have searched and searched through the forum, found many posts, with many different answers.
What is the best recommended spring for the HP500 carb motor?
Stuck between:
Isky - 8005-SP
Isky - 8205 Plus
Which is preferred and why?
Also, if valves are needed, what do you guys recommend for valves?
SmurfOnABoat is offline
Old 01-04-2010 | 11:22 AM
Both are good, the plus is a endurance spring. I chose the endurance spring, it should last longer. A little more money but more durability.
jeffswav is offline
Old 01-04-2010 | 03:07 PM
Throttle Fever's Avatar
What Cam the stock HP500? The Isky 8005 are my choice. Never had a set fail yet, as long as pressures are set right. And you are using good valves. My 2 cents.
Throttle Fever is offline
Old 01-04-2010 | 03:27 PM
Yes, stock cam.
