6.2 MPI Camshaft specs ? >
Old 01-06-2010 | 06:11 PM
Default 6.2 MPI Camshaft specs ?
Happy New Year guys !
Anyone happen to have the camshaft specifications for the Mercruiser 6.2 MPI engine ?
Thanks in advance,
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
Old 01-06-2010 | 11:26 PM
Happy New Year!
Here's a thread on the subject.
http://www.offshoreonly.com/forums/g...-question.html
4mulafastech is offline
Old 01-07-2010 | 06:15 PM
Thank you but ..... how did you find that ? The first thing I did last night before posting my question was to type 6.2 in the search function. Not a thing was found. Just tried it again with the same results ??
Bill
BillK is offline
Old 01-08-2010 | 12:48 PM
I had the same problem. For some reason the search function doesn't pick it up. I knew there was a thread out there where I post info on the subject so I pulled up all my old posts and quickly found it.
Old 01-08-2010 | 04:22 PM
Yes, Happy New Year guys,
my problem here is a frosen crackt block 6,2 Mpi 2002,can I use a ordinary 5,7L block?
Thanks.
502 Magnum is offline
Old 01-08-2010 | 06:04 PM
Thanks.
I am pretty sure the blocks are the same, get the casting number off the block, right behind the cylinder head, that will tell the tale.
Bill Koustenis
Waldorf md
BillK is offline
