Prop diameter ? >
Prop diameter ?
Prop diameter ?
Old 04-14-2002 | 07:59 PM
Sammy
Default Prop diameter ?
Is there a formula for predicting rpm changes based on a diameter change.
THX
Sam
Old 04-14-2002 | 11:18 PM
Blackhawkdn
Default Prop Dia.
There is a direct formular fo prodicting the effect of diameter on power. I am sure what it is off hand. But as you drop dia. the power delivered to the water is reduced increasing rpm. Estimate about 300rpm per 1/4". Hope this helps some.
Old 04-15-2002 | 04:34 PM
Sammy
Thanks ! it might help explain my problem.
Sam
RazorsEdge
Prop Talk
2
05-14-2006 02:28 PM
Shah Mat
5
08-23-2005 05:33 AM
Offshoreracr
4
04-24-2004 01:57 AM
Cord
5
07-15-2003 07:18 AM
Steel Outlawed
Baja
2
05-06-2003 07:42 AM
