Whipples on 496 H.O's >
Old 01-11-2010 | 08:20 AM
Default Whipples on 496 H.O's
Anybody running whipples on there 496 H.O's???Just wondering how your engines are doing and if it's a good investment ?Thanks,Hank35
Hank36 is offline
Old 01-11-2010 | 10:56 AM
I have had a Whipple on my stock 496 for over 100hr and 3 years. There not for everyone and the 496 is not the best powerplant to put one on. But it can live and can be done. I love the Whipple and power is sweet.
I DIG IT !! is offline
Old 01-12-2010 | 07:37 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
I agree. I ran one personally & have done others. They can run quite well if set up right. The downside is they are costly & if you do want to play it as safe as possible then upgrading the insides is an extra expense. But they can be reliable without replacing the internals. But no arguing that Better insides are better.. Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 01-16-2010 | 12:44 AM
Default Whipples
Thanks for the reply Guy's!!I guess I'll just keep the stock set up on my 35.
Hank36 is offline
Old 01-16-2010 | 01:20 AM
Jamie, what kind of power are you seeing with them on stock HO's
JRalston is offline
Old 01-23-2010 | 04:25 PM
I have a little over 250 hrs on mine with zero problems...Love it
And as far as HP ,I would say 625ish is about right
live wire is offline
Old 04-05-2010 | 10:35 PM
Does the whipple kit for the 496 require more room under the hatch, forward and height?
prholley is offline
Old 04-05-2010 | 10:39 PM
The height is the same. If my memory is correct The forward clearance is about another 2" or so.. Jamie / Lakeside
Old 04-11-2010 | 09:42 AM
Do all the pullies get changed out when adding a whipple to add to that 2" more in length????
If not then should it not be the same overall lenth??
verbi69 is offline
Old 04-11-2010 | 09:54 AM
Smitty's Avatar
The key to reliability is in the setup. Whipple kits are the most complete and when setup per Dustins instructions, you should have many trouble free hours of fun.
Smitty is offline
