496 to 496 ho conversion >
Old 01-13-2010 | 04:07 PM
Default 496 to 496 ho conversion
I have a 375 hp 496, the block cracked (and the 525 I really want seems unreasonable right now)
If I purchased the 425 horse version (in a long block) can I have my computer re-calibrated for that engine?
Would I need anything else to make this a true HO?
007joe is offline
Old 01-13-2010 | 06:10 PM
crayolacrazy's Avatar
to make the conversion you need a cam ,the hole in the throttle plate needs drilled ecu need reprogrammed by whipple ,he can give slight up grade at that time 10% on top
crayolacrazy is offline
Old 01-13-2010 | 06:32 PM
PAST DUE's Avatar
wont the long block already have the cam in it ??
PAST DUE is offline
Old 01-13-2010 | 10:18 PM
what do you drill the idle air hole on the throttle plate ?I heard drill it out to a 1/4 ,is that correct?
boatnt is offline
Old 01-14-2010 | 12:01 AM
Wink
If the camshaft in the new long block is the 425HO version , you're good to go on the engine. You can send us the ECM and we reprogram them to HO spec for $675 each. Let us know if we can help.
Best Regards,
Ray @ Raylar
Raylar is offline
Old 01-14-2010 | 08:47 AM
i think drilling the hole in the throttle plate,,,is only done if you put the raylars kits on,,,,,not sure tho
TWIN-SPINS is offline
Old 01-14-2010 | 11:20 AM
Ray does your reprogram change hp at all, or just brings it to straight 425 hp?
Thanks,
Joe
007joe is offline
Old 01-14-2010 | 11:42 AM
I have an HO cam and ECU I'll sell for $750. Just get the reman long block and swap cams.
Bob
bobl is offline
Old 01-16-2010 | 09:43 AM
Wink
007joe:
The Raylar HO replacement camshaft and our in house ECM reprogram will raise the horsepower to about 460HP with everything else stock.
Best Regards,
Ray @ Raylar
Raylar is offline
Old 01-16-2010 | 05:33 PM
Originally Posted by Raylar
007joe:
Best Regards,
Ray @ Raylar
Hmmm?pricing on those is?
10K4U is offline
