Boost gauge necessary? >
Old 01-22-2010 | 10:31 PM
  #31
Wink All Bunged Up!
The bungs should be 18mm same as most sparkplugs and yes 6'oclock is a lousy position. We put ours at 3 o'clock and 9 o'clock depending on which side is better to route the cable. The stainless 18mm bungs sold by most parts houses can be had with the corresponding plug. Where the bungs are placed will vary depending on the exhaust manifolds or headers, but as far back towards the engine as possible and still read all 4 cylinders on a side if possible. This usually keeps them away from water in the exhaust as much as possible and away from water/exhaust mixing points and captains call. etc.
Yes, we only use a wideband 02 sensor for air/fuels, conventional automotive non-wideband would be useless.
I think some of the Napa houses still catalogue the sparkplug anti-fouling adaptors and you are probably correct when you mention good ol J.C Whitney-Boy been a long time since I looked at on of their catalogues!
Best Regards,
Ray @ Raylar
Raylar is offline
Old 01-22-2010 | 11:12 PM
  #32
Strip Poker 388's Avatar
Rob
bung
Attached Thumbnails Boost gauge necessary?-tail%2520pipes%2520003.jpg   Boost gauge necessary?-tp-my-bung-holeia.jpg
Strip Poker 388 is offline
Old 01-22-2010 | 11:23 PM
  #33
Rob
Wink
TP for my Bungholeio
mine is at 11 and 1 oclock
Attached Thumbnails Boost gauge necessary?-tail%2520pipes%2520003.jpg   Boost gauge necessary?-tail%2520pipes%2520005.jpg   Boost gauge necessary?-tp-my-bung-holeia.jpg
Old 01-23-2010 | 05:21 AM
  #34
boatman22's Avatar
On 575SC's where would put the vac/boost fitting?
boatman22 is offline
