chinewalking >
chinewalking
chinewalking
Old 01-20-2010 | 08:45 AM
Ken N's Avatar
Default chinewalking
What is chimewalking and how dose it fill at WOT?.
Ken N is offline
Old 01-20-2010 | 10:45 AM
Its chinewalking. Basically the boat rocks side to side on the rear chines.
Griff is offline
Old 01-20-2010 | 01:10 PM
Strip Poker 388's Avatar
Rob
heres something I found,
Depend on how bad it is,ya really just got to learn how to balance it unless theres something wrong with the steering or bottom.rub rail to rub rail is not fun.
First, "What is a "chine"?" The chine of a hull is where the bottom joins the side. It may be "hard" (a well defined edge) or "soft" (significant rounding, often merely a gentle curve with no definitive break between bottom and side).
ChineWALK is a violent, often rapid, side to side oscillation. Technically, it is literally bouncing from one chine to the other. True chinewalk is one of the most dangerous events that a boater can experience. Any padV hull can chinewalk if there are hull problems, setup is wrong or the driver is inexperienced. Certain wave/wake conditions can force even the experienced driver to deal with chinewalk on a properly set up hull as well.
NOW! Does your boat CHINEWALK? If it does, you have hull/setup problems or you have not yet learned to drive it. Chinewalk cannot be "driven through", but it must be driven OUT OF when it occurs. Typically, the driver must ease out of the throttle while keeping the helm straight. This is not ALWAYS the answer, but dumping the throttle and/or attempting to steer out of this condition can cause total loss of control and lead to an accident, rather than an adrenaline rush, tripled heart rate and a dirty seat.
ALL PadVs have a tendency to "fall off the pad" to starboard (right). This is NOT chinewalk, but, if not corrected, will result in chinewalk! Driving a padV to its limits is a "high wire" or "balancing" act. Prop (engine) torque and load balance are the major factors (assuming a straight hull and good setup) in this condition. Both can be controlled and, in many cases, virtually eliminated.
THE FIRST STEP in gaining control is to assure that the engine is properly mounted (centered and plumb) and there are no hull defects (rocker or hook). Beyond a certain engine height, torque will exist no matter how well balanced the load (see below) and NO, hydraulic steering DOES NOT eliminate torque, it "masks" it. A welded, properly adjusted skeg mounted torque tab will minimize this condition.
BALANCING THE LOAD: As most hulls have a starboard driver console, there is a "built-in" load imbalance to starboard when there is only one occupant. This automatically increases the tendency to fall off to starboard. Proper positioning of batteries and other accessories is one step in minimizing this condition. This is a "static" or not easily adjustable parameter. "Overloading" or storing most tackle and other "removable" items in port (left) side rod and/or storage box(es) helps to achieve balance. Hulls with side-by-side livewells and/or dual fuel tanks offer additional solutions when fishing alone. A 30 gallon livewell system with port side only filled adds about 120 pounds (15 gal @ 8 pounds/gal) to port of centerline and contributes about half that or 60 pounds to balancing the load. Although it would decrease cruising range, similar gains can be achieved by limiting fuel in the starboard fuel tank. Gasoline weighs about 6 pounds per gallon. Do the math! If both fuel tanks must be full at the beginning of the trip, start by using the starboard tank and balance will improve as fuel is consumed. When you add a second occupant, dynamic balance changes and requires a re-think of "what's where?" to balance the load again. If the hull balance is good and the design has "3 across" seating, consider placing the passenger in the center seat for minimum impact.
OKAY, everything's "perfect". The hull is well balanced, mechanical setup is spot on and, if not a *****cat, the boat is now a well trained lion. What I mean is that the stability is still a dynamic condition. Environmental conditions (wind, waves, an unexpected wake or a required rapid/emergency maneuver) are always changing and trying to push the hull off balance. Constant awareness and an almost automatic response (this comes with the now classic phrase, "seat time") are required to assure continued safe, controlled operation. The ball's in your court. Experienced drivers can help you learn, but you must spend the time behind the wheel and learn to anticipate the hull's next "move".
"Wait a minute! How DO I drive it?" The generic answer is "small helm corrections to port as required". Not really a definitive answer, is it? No one can TELL you how to drive YOUR boat. I know it's frustrating and you get tired of hearing or reading "seat time". Although you will pick up pointers, even "show and tell" with an experienced driver at the helm and you as observer will not be enough. The corrections become so nearly automatic that it's hard to communicate "why" I did that or "when" to do it. Overcorrection to port throws the hull past centerline and it tries to fall to port. Undercorrection to port allows the hull to continue to fall to starboard and requires additional correction to port, often resulting in overcorrection. Each under or overcorrection requires a larger correction to compensate and, if that correction is too much or too little, the oscillation increases. This is the beginning of chinewalk, the time to ease out of the throttle and start over BEFORE it becomes dangerous.
You CAN do it! You must set aside on the water time to concentrate on your driving skills just as you would learning a new fishing technique.
http://www.bassboatcentral.com/new_page_2.htm
http://www.boatdesign.net/forums/sta...ing-17405.html
these aren't bad.
[YOUTUBE]http://www.youtube.com/watch?v=v9Yvj1FPR3s[/YOUTUBE]
[youtube]http://www.youtube.com/watch?v=3hZcEKeHlG0[/youtube]
Strip Poker 388 is offline
Old 01-21-2010 | 10:07 AM
14 years ago i owned a 20ft flat baja that had a 300 black max. the pitot speedo only went to 80 mph and i went well beyond that. At about 60 the chine walking began and as I increased throttle it went away. If I left it at 60 it would just get worse. I really didnt know what chine walking was.
At the time I had no internet so I wrote a few letters to Baja, Canadian coast guard even a boating tv show, but got no real responce to my inquiry as to what was happening. Just by chance while on an evening river cruse while bragging to the captian about my rocket ship I asked him about the rocking side to side. Well he tuned me like a ferrari on how dangerious this was and to stay off the throttle, get a smaller engine, sell the boat, or die. he assured me my insurance co. would not pay out a clame if they saw the boat overpowered like that. He scared the pants off me !!! I sold the engine by itself for what I paid for the boat $10.000, and put a 175 mariner on The boat went about 55 mph if I remember correct with no chine walking.
I new I was running out of boat at thoes high speeds but did not understand the dynamics of chine walking and it in sites like this that inform and educate boaters of such dangers. I was a lot younger then and far more stupid that I think I am now.
One last point of intrest is here in Canada they are phasing in the opperator cards and there are no provisions to insure boaters are informed about the handling of vessels and what to watch for. I love going fast but only within the limits of the equipment.
The following is not really chine walking but a portrate of where I was heading. in the search for speed please be careful everyone.
P.S. Dont show the wife this video.
http://www.youtube.com/watch?v=1UEETjztLqI
toolsinbox is offline
Old 01-21-2010 | 10:12 PM
Rob
that wasn't from chine walking,thats the Ross Barnett reservior we boat on every weekend.Still over his head jumping wakes.
Rob
Old 01-22-2010 | 04:24 PM
blue thunder's Avatar
That's is a good example of over trimmed. BTDT.
blue thunder is offline
