Distributer question >
Old 01-22-2010 | 08:09 AM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
Default Distributer question
Is a tall deck distributer differnt then a standard deck And if so will a tall deck distributer work in a standard deck motor?
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Old 01-22-2010 | 09:36 AM
Yep, they're different, they're taller, who'ld have thunk?
The intake sits higher.
I've seen tall deck distributors with an adjustable collar to fit either block.
rdoactive is offline
Old 01-22-2010 | 09:58 AM
if you want to install tall deck dist in a shortdeck,you make a spacer.i have done this,made it out of brass.
mike tkach is offline
Old 01-22-2010 | 11:13 AM
The VAST majority of tall deck manifolds are machined to accept a standard dist. They cut the dist. pocket in the manifold deeper. I can't remember the last time I had to use a tall deck dist., and probably 95% of what I build are tall decks. However, I do usually use a dist. with a slip collar so that I can get the exact height needed and not have to use shims. There is about a 99% chance that the tall deck manifold you have will take a standard dist.
EDIT:
Sorry, I just re-read your question. If you do in fact have a tall deck dist. then you can have the base machined off and use a slip collar. It's very easy to do on a lathe. Just because it came off of a tall deck engine, don't assume it is a tall deck dist. Like I said, most use a standard dist.
Eddie
Young Performance is offline
Old 01-22-2010 | 03:28 PM
Even the Mercury tall deck and standard deck distributors are the same.
brian41 is offline
