Speed Pro Piston Installation >
Old 01-31-2010 | 10:42 AM
Default Speed Pro Piston Installation
I am installing Speed Pro 2399 pistons in my 454, but the machinist did not return my install instructions. Should the lettering and number be right side up? The piston does not have a conventional arrow or notch in piston.
The reason I am queston it is that he installed the rods the other way around, so the stamped numbers are on the inside.
Thanks for the help
OhioRiverCigarett is offline
Old 01-31-2010 | 10:49 AM
the intake valve releifs go on the top right when installed in the block.this is for both banks.
mike tkach is offline
Old 01-31-2010 | 10:53 AM
PatriYacht's Avatar
On a big block Chevy, it's easy to see which way they go. Just match the valve reliefs to the heads.
PatriYacht is offline
Old 01-31-2010 | 11:00 AM
Default That is the concern
The 2399 speed pros that I am running would have the labeling on the piston upside down, does that soun
d correct?
Old 01-31-2010 | 12:15 PM
Default Fixx
What everybody else said! also look ar the rod journal where cyl 1 & 2 mate on the crankshaft. the rod;s are offset a bit the slim side of the rod journals mate each other on the crank.
FIXX is offline
Old 01-31-2010 | 03:11 PM
Let's just hope your engine builder installed your pistons the right way. Thats happened more than once. I finally built my own press a couple of years ago and do it myself now. I know this is not your question and I'm sure you know but make sure your pins are oiled good. Really work the oil in good by working the rod back and forth, side to side while appying oil. If I am in a rush I will place the pistons/rods in the oven after assm. and heat them up with the door cracked at 200 deg. This will allow the oil to get in much quicker and easier. If I have time and not in a rush I use a cake tin or something similar with enough oil in it to go past the pins and let soak over night with the top of the piston facing downward. If doing it the first way mentioned I like to use the red cam lube. Just a preference. Also good if the engine is going to sit for a period of time before running.
getrdunn is offline
