HP500 Cam Help >
HP500 Cam Help
HP500 Cam Help
Old 02-12-2010 | 03:54 PM
Heads are just not in the cards for this year.. I better set the sights down to the mid 90's for this season. What cam should I buy for my setup though??
ryanmcclaran is offline
Old 02-12-2010 | 09:31 PM
Default cam chioces......
like the others said, your lobe sep. is all wrong for a blown motor! I've built quite a few blown motors , both for cars, and
marine applications, and it really isn't feasible to run anything
less than a 112*. a good example is my current boat, a 25'
Ultimate Warlock SXT cat, with a bone stock 450hp 502 w/ a
2.3 whipplecharger/ intercooler setup. It would run 96mph
all day long (yes on gps) that factory cam is miniscule 480lift
but on a 115 lobe seperation! not the ideal cam by far, but it
makes 6-7 lbs boost, and is packing the cylinders pretty decently. your cam, while the lift and duration is pretty decent,
that 110* seperation angle is blowing alot of boost right out
your exaust! in other words, too much overlap! I'd say pull it out and have itreground, but that is the only thing that can't
be changed when you regrind a cam! my suggestion is to
look for somthing close to what you have, only on a 114*
LC! it would make a night and day difference, been there,
done that!
blownjet 468 is offline
Old 02-12-2010 | 11:05 PM
Strip Poker 388's Avatar
Rob
but on a 115 lobe separation! not the ideal cam by far, but it
that 110* separation angle is blowing alot of boost right out
done that!
The 741 is the same on my engine,also have low port velocity.Over lap is bad ,The factory 500efi cam they say is alot better with the blower.
rob
Strip Poker 388 is offline
Old 02-13-2010 | 01:52 AM
525EFI cam would be a good choice. Its a Crane 741 on a 114 lobe sep.
Griff is online now
Old 02-13-2010 | 09:46 AM
I have read about that cam but I cant find one anywhere? Do you know of somebody that might have one??
Old 02-13-2010 | 02:36 PM
You will probably have to call Crane and special order it.
Griff is online now
Old 02-13-2010 | 02:51 PM
Doesn't Jegs still have those grinds.
getrdunn is offline
Old 02-14-2010 | 01:31 AM
The 525EFI was never available without a special grind order as far as I know. These are about the only 2 cams available off the shelf from Crane for Marine BBC since the company restarted. The 139011 is the old Crane 731. The 139651 will need to be spun faster to make its full potential power. I would spin it to around 5600rpms. Either one would be an improvement, but probably not as good as the 525EFI cam. Like was said earlier, you should contact Bob Mandera aka rmbuilder on this site. He can have a custom grind done to optimize your set up.
http://www.summitracing.com/search/P...yword=camshaft
Griff is online now
Old 02-14-2010 | 02:56 PM
139021?
http://www.jegs.com/i/Crane/270/1390...d=Crane+139021
getrdunn is offline
Old 02-15-2010 | 12:07 PM
Originally Posted by getrdunn
That is the regular 741 with the 112 lobe sep.
I can't keep track of all the new part numbers any more. Both Jegs and Summit don't show all the cams available when you do a search, even though they have it in stock. Seems like unless you have the part number, you can't find what you need.
Griff is online now
