Turbo Prop ? >
Turbo Prop ?
Turbo Prop ?
Old 04-17-2002 | 09:16 PM
Sammy
Default Turbo Prop ?
Is anyone using a Turbo prop out there. I have heard that they will out perform Mirage props on a regular basis mainly on smaller boats, 26' and under.
Sam
Old 04-18-2002 | 07:53 AM
sam, i used a 4 blade turbo prop on my last boat! it was a very good prop after labbing! they are made here in INDY by precision propeller. they do work better on the smaller boats.here is their number 317-545-9080 or 1-800-922-9955 ask for mark croxton tell i sent you bill chambers
wild willy is offline
Old 04-18-2002 | 10:31 AM
imq707s
I've got a 14 1/4" x 22P 3-blade turbo on my 21' Scarab with 350 and alpha I drive. I've never tried another prop on it but it seems to run great. 59-60mph on the gps @ 4500 rpm. I did have a prop shop put some extra cup in the blades. It lower the rpm around 100 but the speed stayed the same and the prop has a little more lift on the hull now.
Old 04-18-2002 | 09:08 PM
Sammy
Wilid Willy, I ordered my Turbo and should have it for the weekend. I'm going to run it on a 16" Donzi with a 350/alpha. I'm hopeing for a couple more mph and a little help with the chine walk. Even with my tabs it can get a little hairy sometimes. If this works out I'll have a couple new Mirages I'll need to sell. Thanks for your feed back and I'll let you how things work out.
Sam
bblythe
12-07-2007 11:18 PM
382 newbie
7
05-18-2007 07:56 AM
customryder
Hustler
45
07-06-2006 11:33 AM
onesickpantera
Prop Talk
4
05-19-2006 07:53 AM
onesickpantera
Prop Talk
23
05-13-2005 10:30 AM
