502 head gasket?? >
502 head gasket??
502 head gasket??
Old 02-15-2010 | 06:56 PM
Default 502 head gasket??
I pulled my pro charged 502 last fall. Wanted to freshen it up for this coming season. When I dropped the pan I found a frozen chuck of ice in the oil. NO GOOD.. Motor ran fine when I pulled it.. What do you think??
Brushwolf243 is offline
Old 02-15-2010 | 07:12 PM
You are really just going to have to take it all the way down and check everything to be sure of the problem. I just found our I had two cracked 540 blocks in my boat, very expensive day. And now I have some nice paperweights, lol. Thought no matter what is wrong with yours that might make you feel a bit better
halfbuzzed is offline
Old 02-15-2010 | 07:38 PM
Not sure what the temps are where your at however was it winterized OK. Any signs of bad head gasket. Were all the freeze plugs in right and not pushing out? If the block is cracked more than like you'll see it when you pull the intake. Look above the lifter galley on both sides of the block. Otherwise when you pull the heads you see it there also. Keep us informed.
getrdunn is offline
Old 02-15-2010 | 07:45 PM
local shop drain and filled with RV anti.. What do I look for on the headgaskets?
Old 02-15-2010 | 08:33 PM
The head gasket, if bad, you'll identify it right away. It will be obivous and you'll see where water was passing through. Look around the water passages/ports. I don't think it's a head gasket. Lets hope so. Did you pull your heads yet? Any gasket I have blown most often resulted in the water blowing out the exhaust. How big was the ice chunk?
getrdunn is offline
Old 02-16-2010 | 04:28 PM
Default Fixx
RV antifreeze???? that stuff is only good for +17 above zero then it turns into slush...how big was the ice chunk?
FIXX is offline
Old 02-16-2010 | 09:20 PM
ice was about 5'' long 2.5"wide 3/8 thick..
popped heads off tonight--- no visible damage, going to tear down and take to machine shop this weekend.. Frost plugs all intact.. Could it be an exhaust manifold???
Old 02-17-2010 | 01:52 AM
It could have been some condensation in the oil that froze
Griff is offline
Old 02-23-2010 | 08:21 PM
got block and heads back--no cracks
Exhaust issue??
Old 02-24-2010 | 08:03 AM
ballon78's Avatar
intake gaskets was maybe leaking a bit..
96 HUSTLER 32, Vacuumed bagged layup, composite transom Blueprinted 502EFI's Mayfair, Dry-exhaust
ballon78 is offline
