TRS - tilt/trim VERY slow (is this normal)? >
Old 02-17-2010 | 10:36 AM
Default TRS - tilt/trim VERY slow (is this normal)?
I've never had a TRS drive before, so I'm not well informed about them.
It's a 1980 Excalibur w/ (I assume) original TRS drive.
The drive moves VERY slow (up and down). Is this normal?
Does the pump need servicing of some kind when it get slow like this or is there a common/known problem I should know to check?
Thank you.
KSims1868 is offline
Old 02-17-2010 | 11:05 AM
Thank you.
I have the same problem, execpt one of mine moves lower than the other, I just havent looked into the cause yet.... maybe i will too feed from your question...
Thanks.
theadamv1 is offline
Old 02-17-2010 | 11:18 AM
Picture of my TRS...in case this helps.
Attached Thumbnails TRS - tilt/trim VERY slow (is this normal)?-1980-excalibur-rear.jpg
Old 02-17-2010 | 06:40 PM
Default TRS rams
TRS rams move slower because of the design of the hydraulic cylinders: the travel distance is longer.
GERRYM454 is offline
Old 02-17-2010 | 06:51 PM
My drives actually move pretty quick up and down. Does your pump sound strong? I know when I hit my trim switch I can hear it kick on strong and it sounds like it has some power.
wjb21ndtown is offline
Old 02-17-2010 | 06:56 PM
Biggus's Avatar
It's probably the trim cylinders sticking. Also, if you upgrade the trim pump to the newer style Oildyne pump the trim will run faster.
Biggus is offline
Old 02-17-2010 | 07:13 PM
Rookie's Avatar
Thank you.
I had the same problem with my boat when I bought it. My TRS drives were somewhat slow. I tore the the trim motors apart and cleaned up any oxidation inside and around the copper coils. I replaced the worn out brushes. I got the brushes at the local alternator/starter rebuild shop. I also ran new + and - wires to my pumps. This helped considerably.
Rookie is offline
Old 02-17-2010 | 10:32 PM
Default TRS trim
I will check my system out: I am comparing TRS to the newer drives and compared to them it is slow but precise.
Old 02-18-2010 | 08:38 AM
I'm comparing it to my 1989 22' Scarab with an Alpha. That Alpha was pretty fast, but this TRS creeps...seriously!!
Old 02-18-2010 | 01:07 PM
Thanks.
I had a similar problem but I had one of my TRS drives that wouldn't go up as high as the other side. Pulled and cleaned pumps but still had the same problem. Bled the line and problem solved.
Mach 1 is offline
