-   -   reverse rotation engine (https://www.offshoreonly.com/forums/general-q/224846-reverse-rotation-engine.html)
88scarab 02-20-2010 05:57 AM
i have a 502 that the customer says it is a reverse rotation. was wondering if all you have to do is change the cam and the starter also the distributor gear to turn it back to standard rotation. will be pulling off timing cover today to verify.
Clustergear 02-20-2010 06:52 AM
Don't forget to change rear crankshaft seal
ezstriper 02-20-2010 08:02 AM
also, some engines had the pistons reversed as well....
f_inscreenname 02-20-2010 08:49 AM
and the timing chain cover seal.
I wouldn't think the gear on the dist would have to be changed. In most RR motors the cam still spins the right way it's just the crank that spin "backward"
Also if the motor has been run you may have to have the crank resurfaced due to the scales on the metal would be going the wrong way.
RdRacerZ28 02-20-2010 09:35 AM
Oil pump too? Had friend with the same problem in a Chris Craft Roamer and I think he had to change the oil pump.
88scarab 02-20-2010 10:27 AM
ok i was just hoping to swap a few things and then ready to go so i mite as well rebuild this thing and i thought 502s never came reverse rotation and i believe its a gen5
Griff 02-20-2010 10:59 AM
Have you turned the starter over to verify its a reverse rotation????
f_inscreenname 02-20-2010 11:33 AM
oil pump should be the same
88scarab 02-20-2010 11:50 AM
i have not im going to look at it today
RdRacerZ28 02-20-2010 02:00 PM
You are correct, I spoke to soon :)
Boat Tech 02-21-2010 12:58 AM
http://www.wikihow.com/Determine-You...ngine-Rotation
Some Mercruiser Inboard (NOT sterndrive) engines can be RH rotation.
Engine rotation is determined by looking from the flywheel end towards the pulley end.
Left hand (LH) engines are standard rotation. Also known as Counter Clockwise Rotation (CCR).
Right Hand Engines (RH) are reverse rotation. Also known as Clockwise Rotation (CR).
Chances are you have a LH standard rotation engine especially if it's a sterndrive or a single engine installation.
Usually only older twin inboard powered vessels have one engine RH reverse rotation.
Do not confuse engine rotation with prop rotation. They might not (and usually are not) the same.
LH and RH engines have a different firing order.
Most Mercruiser LH standard rotation engines use a timing chain whereas RH reverse rotation engines use only timing gears. RH and LH engines have different camshafts.
The distributor shaft rotation is the same for RH and LH motors and it is usually almost always a distributor shaft right hand rotation as viewed from above.
Some engines have the firing order cast or stamped into the intake manifold.
Your need to know the engine rotation to set your ignition timing.
RH and LH engines have different timing specs.
Use care when using a variable timing light as it must be set to zero when timing a reverse rotation engine.
rdoactive 02-21-2010 07:51 AM
You know wnen I read this I was thinking the same thing. By the time Gen V engines came out, I thought merc had changed over to Hurth transmission (full power reverse).
But not sure about other manufacturers, Crusader, etc. Also not sure if someone could have swapped out a Mark IV 454 timing gear set and cam into a 502.
Just pull the timing cover and check for gears instead of a chain cam drive.
ezstriper 02-21-2010 09:08 AM
that merc stuff is old..they still reverse engines but they were all done at whatever marinizer was doing the engine, they do not use gear to gear anymore(I have a gen VI reverse) special cam and distributor, not just the gear...as it will eat distributors like you would not beleive...I went thru 4...as the reverse cut dist gears pulls the dist shaft down and with no thrust to absorb the load destroyes itself in no time at all....
