How to get to 80 mph with a single screw >
Old 03-03-2010 | 05:35 PM
  #31
Stock timing was right around 35 degrees if I remember right, boost from Merc was at 4.5 - 5 lbs. With the chillers and smaller puley I was at 7 -7.5 lbs of boost, what you need to remember here is that the higher boost intercooled is in fact easier on the engine than the stock boost without it. I had the CMI E-Tops, ran the stock timing, with the carbs just a little on the fat side on the top end and they ran like champs, never a single problem. I remember reading an article on supercharged engines in Hot Rod magazine years ago where they stated the most reliable factory SC package ever marketed was the Merc HP 525 SC.
RaggedEdge is offline
Old 03-03-2010 | 06:05 PM
  #32
Originally Posted by OUTLAW24
Be careful of just adding the smaller pulley without lowering the timing down to 30 or 32. I also sent my carb. out to Nickerson for a rebuild as the engine was very lean before the rebuild after adding the pulley. Last idea may be to go to big tube headers from CMI or Lightning.
I don't think lowering the timing is such a great idea. My boats previous owner did it and the exhaust valves were done at around 150 hours. A stock timing curve has a lot of timing but it comes in late, like stated above.
Old Navy is offline
Old 03-04-2010 | 02:57 PM
  #33
30 or 32!!!??? Im currently running it at the stock 13 degrees. Please do educate me on this one!
Kid Cumberland is offline
Old 03-04-2010 | 02:59 PM
  #34
My Bad. Yall must be talkin about WOT timing.
Old 03-04-2010 | 11:31 PM
  #35
ZXXX Donzi's Avatar
Those are pretty good numbers in that boat. Unless you have a screwed up prop, I seriously doubt you will get 4 mph by cutting on the wheel. And yes, I have some pretty good experience with a dialed in single engine.
If you want you can blow a few grand on a prop and exhaust for that extra mph or so. Bottom line, you are running good numbers and it will take some more power to get 80.
Don't get me wrong, a labbed prop has its place but big singles like power.
I run WELL over 80 in a single screw and have been fooling with them for quite some time.
ZXXX Donzi is offline
Old 03-05-2010 | 01:06 AM
  #36
That was the beauty of the 525. It had so little comp to start with that you really could boost it up pretty good.
My guess would have been to upgrade the exhaust to a tube header and then get the prop done by BBLADES.
Prolly pick up way more than 4mph.
I switched from the stock Merc Gils to CMI's and gained ZERO on the top end. Actually, Merc switched to CMI's the last year or two that they made 525SC's.
Griff is offline
Old 03-05-2010 | 01:13 AM
  #37
I ran just shy of 8# of boost for almost 300hrs without a chiller . Timing was set at the stock 35*. I only increased the carb jetting when I put in a bigger cam(731).
Like all Merc stuff, the stock jetting is set up on the rich side with #98 jets on all around and 6.5 PV's on both sides.
What was the stock overall timing for a 525 sc, and what was the stock boost setting with the factory GIL exhaust?
13* at idle with a 22* module that made full advance at 4250rpms for a 35* total. Stock boost is 2:1 overdriven for 5.5#.
Griff is offline
Old 03-05-2010 | 06:12 AM
  #38
what I do not understand, if you talk to the blower guys at weiand (who made the blower setup on a 525) or read the install manual, they recomend a max timing of 26-28 deg...whats up with this....I have always found backing the timing down under boost works best...Rob
ezstriper is offline
Old 03-05-2010 | 11:45 AM
  #39
Blower engines like all the timing they can get and as long as its not having detonation issues, its fine. The 7.5:1 static comp ratio in the 525SC allows you run more timing and boost without having to worry about detonation.
Griff is offline
Old 03-05-2010 | 03:27 PM
  #40
This little cutie last summer went 95 on my boat after screwing me once
Andy is offline
