HP limit for imco exhaust >
Old 02-26-2010 | 08:57 PM
Originally Posted by PAST DUE
Just picked up my engines from Tyler Crockett last week 454 mags with side mount whipples (with intercoolers) 712 hp @5300 rpms 815 ft pounds of torque @3500 rpms fine tuning to be done after break in and installed in the boat
Those are some pretty respectable numbers. How would you compare the side mount whipples to blowers? Sounds like that is a much better way to go. Also how does the pricing compare to that of a 250 or 420 mega blower?
getrdunn is offline
Old 02-26-2010 | 10:56 PM
Strip Poker 388's Avatar
Rob
Nice #'s,You should be broke in after the dyno runs,Mine seated the rings on the 3rd pull,put it in the boat,ran it hard,same as with the races cars.
keep us posted on how the boat runs
Rob
Strip Poker 388 is offline
Old 02-27-2010 | 11:43 AM
PAST DUE's Avatar
getrdunn, dont know any thing about the other blowers compared to the whipples but my choice would be for the fuel injected set up because of the ability to tune and all around running. Will do STRIP cant wait to get them back in and start running and testing props any one have any idea of where i might end up prop wise. was turning 28p bravos 5400 @ 86 mph with 1.36 gears that was with 470 hp per side??
PAST DUE is offline
Old 02-27-2010 | 01:58 PM
PAST DUE's Avatar
http://www.youtube.com/watch?v=RroIhsESGug This is a dyno run at Tyler Crocketts.
PAST DUE is offline
Old 02-27-2010 | 05:01 PM
Rob
thats good #'s with the 28's,i guessing 32's
I turned a 28 6000 at 760hp but the gear was a 1.30.Thats with no testing and I got 99.8 out of it.
Rob
Old 03-05-2010 | 08:36 PM
PAST DUE's Avatar
http://www.youtube.com/watch?v=Uq4XevC3xXk first start up stb engine after install
PAST DUE is offline
Old 03-05-2010 | 11:22 PM
hey past due, what size pulley are you running? and how much boost? Are you running aluminum heads?
conquest30' is offline
Old 03-06-2010 | 05:56 AM
PAST DUE's Avatar
3 1/8 pulley Dart Alum heads 5 p.s.i. boost
PAST DUE is offline
