HP limit for imco exhaust >
Old 02-23-2010 | 11:16 PM
Default HP limit for imco exhaust
I am just finishing up my 509 c.i sidemount whipple engine built. Im shooting for 700-750hp. I currently have some older imco powerflow exhaust. Will this exhaust support this HP? or do I have to upgrade to the powerflow plus or tube headers? Thanks in advance for the help
conquest30' is offline
Old 02-23-2010 | 11:39 PM
I had the same in the past with 800 SC hp and no problems if you have the xtra money to burn I would get me a set of cmi headers maybe get extra 2mph for about $3,000 plus
sosatime is offline
Old 02-24-2010 | 12:20 PM
The exhaust will be fine an SC'd engine. I don't think you'll be able to make thta kind of HP with a sidemount whipple though.
Griff is offline
Old 02-24-2010 | 03:11 PM
ak
Default whipple horsepower
I am not sure why you could not make that horsepower with a 509 with that whipple,i have a 509 with some big heads and it made 690hp n/a,i would think it should be at least that power with that blower.
ak is offline
Old 02-24-2010 | 05:27 PM
At what rpm did it make 690 HP ???
kreed is offline
Old 02-24-2010 | 06:11 PM
PURPLE HORNET is offline
Old 02-24-2010 | 06:16 PM
Strip Poker 388's Avatar
Rob
Does the side mount have a innercooler????
Strip Poker 388 is offline
Old 02-24-2010 | 09:04 PM
PAST DUE's Avatar
Just picked up my engines from Tyler Crockett last week 454 mags with side mount whipples (with intercoolers) 712 hp @5300 rpms 815 ft pounds of torque @3500 rpms fine tuning to be done after break in and installed in the boat
PAST DUE is offline
Old 02-26-2010 | 07:47 PM
yes it has a cupernickel intercool. hey past due, what kind of exhaust are you running? and do you know your cam specs? are your 454's stock or built? thanks
Old 02-26-2010 | 08:42 PM
PAST DUE's Avatar
CMI E tops dont know the cam specs it's Tylers special grind with the firing order changed up the motors are bored .30 over Dart alum heads Eagle rods Diamond pistons and a lot of other good stuff
PAST DUE is offline
