I was real wondering that from this small hole comes 380 HP and 80 Nm more than 496 HO!!
:poopoo: I cant await to drive my open Ho version! Michael |
Just giving this thread a bump. I removed my cats, there were 3 on each side. 6 cats on this motor! I also got my air intake adapter machined to remove the restrictor plate. Whipple received my PCM last Friday April 25th. I'm all ready to go once whipple sends the PCM back. I will take it for a test drive as soon as I get it back.
Originally Posted by BrianH244
(Post 4116534)
Originally Posted by Pismo10
(Post 4116535)
Very cool, looking forward to hearing results. Which Whipple flash did you get? Sounds great. Lots more hp there to be had.
Well, I finally went for a test run and it didn't go well. I'm getting an alarm under hard throttle around 4500-4600 rpm. It's cutting the motor out with a long continuous beep. The warning says "guard active". I'll be calling whipple to see what the problem is.
Not good to hear!
I have not test the pcm as i make first start of my enige next week and first in 380HP version the first 20-30 hours!(i buy second airintakeadapter and complett new PCM. But i have no CAT engine and think you can not take out the cats and it work! Hope you get soon news from whipple and post here! Michael |
Brian,
I went back through the cal, looks like I may have left the exhaust manifold coolant temp guardian on. And if there not plugged in right now, they will set a EMCT high or low fault. I had to build a new file for yours, must have missed that. For a test, you could remove the sensors from the stock exhaust and plug them in and see if the guardian goes away (it should). There was also one O2 adapt check I missed but I don't think that will set a code since the function is turned off. If you want to get the PCM off and shipped back to me, I'll overnight it back to you. Thanks Dustin |
As i think before there something with your CAT deactivation!
At my engine is at moment the stock exhaust mounted! So this will not a problem at me as both sensors mount at my exhaust! But good to know that they must deactivated if i ever mount an CMI or so. The exhaust on my engine is same as 496,so i try to hold it some times as they not so bad as CAT exhaust! Thanks for info and pleas tell if you get is run next time and how much more performance you boat get!! Michael |
Any updates? How did it run ?
How about yours ^^^^^^ any updates
| All times are GMT -5. The time now is 09:05 PM. |
