How do I get rid of porpoising problem?
I have no idea why your boat porpoises, agree with others about 4 blade and hook etc
My 26 and then 27 only porpoised in the Spring... Why??? I think the trim pump needed to be run up and down several times to remove any air from long storage..or even pressure test pump to ensure drive is staying put..ie no leaking seals.
And I think winter storage puts a set in the hull from the trailer which in my case works its way out with use.. Look at your bunks and ensure they are straight..surely your boat doesn't hang off the bunks to further the hook??...SKY
