-   -   Help with new carb (https://www.offshoreonly.com/forums/general-q/225273-help-new-carb.html)
noles5309 02-26-2010 10:58 AM
Help with new carb
I am looking for a new carb for a stock 454 Mag in a 26ft Checkmate. I am pretty sure it has a Weber on it now. I want something that is easy to tune in and reasonable in price.
Any Suggestions?
wjb21ndtown 02-26-2010 11:09 AM
Any Suggestions?
Edelbrock is probably the easiest to tune, but I wouldn't think it is much of an upgrade over stock. The Holley 4150's are pretty good, a little harder to tune, but pretty good. How much do you want to spend and what do you want to get out of it? If you're just changing the carb I wouldn't expect much of a performance increase. Do you have the 370Hp. Mag?
blue thunder 02-26-2010 12:05 PM
This would be a good choice. You might need an adapter but it would be the best carb for your 365hp mag in my .02. Good price too.
BT
http://www.speedwake.com/newclassifi...uct=1823&cat=4
two-rocks 02-26-2010 12:18 PM
I have a barely used Edelbrock 750cfm from my BBC project (40 hours). I never made any adjustments to it out of the box. Cheap... I have too many boxes of 'stuff' !
FIXX 02-26-2010 01:55 PM
Fixx
whats wrong with the one thats on their?
is it bogging and running out of fuel?
ballon78 02-26-2010 04:39 PM
weber, is a edlobroc, is a afb they are all the same casting....either rebild yours or go holley
rdoactive 02-26-2010 04:51 PM
Why do you think you need a new carb?
Why do you think you need to tune a carb for a stock engine?
Why do you think tuning any other carb would be easier than the weber/afb style?
FIXX 02-26-2010 05:32 PM
Fixx
UUUMMMM Why you quoting me,,your telling me something i already know! :) I'm just trying to figure out what he is having problem's with and why he wants to change it..I know those carbs and what problems occur.
noles5309 03-01-2010 09:02 AM
After I run for a while and turn the engine off it takes a long time to start. I have taken it apart and cleaned and replaced gaskets. I have tied the choke open. Nothing has seemed to help.
FIXX 03-01-2010 09:31 AM
Fixx
Remove the screens that are in the needle and seats(they get plugged with crap),also it helps if you dont touch the throttle if the engine has been warmed up..it will snap the choke shut and can be a *****,i hate the electric chokes!!
