dry exhaust ??? >
dry exhaust ???
dry exhaust ???
Old 03-09-2010 | 08:44 AM
Default dry exhaust ???
Hello All,
I have a brand new engine big block 500hp. I need to make some adjustments to the stainless marine risers. the holes don't line up. I would like to make it a dry system and had clamp on mufflers. The risers are the stock heigth not alot of angle. Which would be the best way to go, just move the water mixture back or go dry exhaust. I'm on a small budget. Jp.
alecsammy is offline
Old 03-09-2010 | 09:26 AM
I'm in the process of doing the same thing with my S/M exhaust. Stainless wanted $1600 for new long risers, I think I can just have them extended for ALOT less. I'm curious to see the input on this.
endeavour32 is offline
Old 03-09-2010 | 05:52 PM
i call jerry at stainlless marine and he made me new tops pipes they are dry to the back and the water comes out the end . they work great . i got a 540 dart was 624hp last year no promblems now going bigger same exhaust. ps he made them so they fit the same hole that were there . he is good
bajabob is offline
Old 03-09-2010 | 06:02 PM
ya i was going to do the same as you . i price out the stainlless tubes then look into some one to weld them . i call a few welders . no one will say how long they will last?????my old exhaust is 20years old so i went with jerry . i have to much money in my motor to worry about my exhaust that my opion good luck
bajabob is offline
Old 03-09-2010 | 06:26 PM
Keep in mind that some of the clamp on mufflers are not designed for dry pipes. I used to have dry on twin 502's but when I started to run clamp on mufflers I drilled a 1/4 inch hole at the very end of the pipe to let just enough water out to keep the rubber seals in the mufflers from burning up.
I will tell you that dry pipes are really loud!!!
502ss is offline
