Not to expensive spark plug wire set question >
Old 03-16-2010 | 09:13 PM
Default Not to expensive spark plug wire set question
I can't use the wire I had for my jet boat on the Baja. I have to run them under the exhaust headers. The wire set I have is not long enough. Is there a good set around I can buy? If they sell a set you cut to fit.Thanks Mike.
89 Baja 250 is offline
Old 03-17-2010 | 12:57 AM
There are several companies that make wires for under headers and marine engines. They have premade and cut to fit. Just check Summit or Jegs.
Griff is offline
Old 03-17-2010 | 04:42 AM
Mr Gadgets's Avatar
Charter Member #601
Mike,
get your hands on a MSD catalog, or possibly online. They have a universal set that can be cut to length. But you take a chance of problems with putting your own ends on.. They come with the plug end already on, you install the coil end. In the MSD catalog you can find the lengths of the universal sets and the factory made sets that install under the headers. That will give you an idea of length and what you have now to for comparison.
Dick
Mr Gadgets is offline
