Which thermostat in a 454SC engine? >
Old 03-25-2010 | 10:34 AM
Default Which thermostat in a 454SC engine?
Have newly rebuilt 454 with 177 Blowers. Had high flow brass thermostats when I got the boat. Stats say V142 and 4H7 on the bottom. Should I stick with this style stat and keep water temp at 140? Engines have crossovers.
kreed is offline
Old 03-25-2010 | 10:55 AM
couple pics of the old ones....
Attached Thumbnails Which thermostat in a 454SC engine?-008.jpg   Which thermostat in a 454SC engine?-009.jpg   Which thermostat in a 454SC engine?-010.jpg
kreed is offline
Old 03-25-2010 | 12:01 PM
Thunderstruck's Avatar
Keep water temp at 140F. Sea water has salts, other than table salt, that precipitate at higher temps causing scale in the water passages of the block and heads. See you are in CT so the sea water part applies to you right?
Long time cult member.
Thunderstruck is offline
Old 03-25-2010 | 01:41 PM
Well, the boat will be on a lift on the Ct river about 40 miles from the ocean, so its fresh water. But, we do go in the ocean alot. So, alittle of both, salt/fresh.
kreed is offline
Old 03-25-2010 | 01:54 PM
The 525SC's that are very similar to your engines use a 140* tstat. I would keep the 140* unless you are having problems.
Griff is offline
Old 03-25-2010 | 02:40 PM
Ok, will do!
kreed is offline
