Valve springs 500 EFI >
Old 03-26-2010 | 07:50 PM
Jim Diesel's Avatar
"Unregistered Gun"
Default Valve springs 500 EFI
What brand of valve springs are you guys using for a 500 EFI? I have heard people use Crane or Isky alot...
Jim Diesel is offline
Old 03-26-2010 | 08:38 PM
REMEDY's Avatar
Take a look at Pac Spring. Anything that is a new high silicon pacalloy process spring will last forever. I recently used a set of Manley Nextec on Hp500 heads. They are made by PSI Spring, as are Isky springs.
REMEDY is offline
Old 03-26-2010 | 09:41 PM
Isky 8005sp
formula 382 sr-1 is offline
Old 03-27-2010 | 08:48 AM
Michigan Mad Man
Originally Posted by formula 382 sr-1
Isky 8005sp
I use a lot of the Isky 8205
TylerCrockett is offline
Old 03-27-2010 | 09:20 AM
Strip Poker 388's Avatar
Rob
Talking
Tyler whats the spec diff VS the comp 929? Being its going on a stock 500efi
Rob
Strip Poker 388 is offline
Old 03-27-2010 | 07:24 PM
Jim, call Eddie he's not to far away. He will sell you the right upgraded retainers and keepers to go with the springs.
45SS is offline
Old 03-28-2010 | 04:17 PM
Jim Diesel's Avatar
"Unregistered Gun"
Whats the diffrence between the 8205, 8205 PLUS, and 8005sp? If my leak down shows good should I still replace them since it has 360 Hours?
Im going to give him a call after I do a leak down test!
Old 03-28-2010 | 09:02 PM
Leakdown really doesnt tell you whether your valve springs are weak or not. I would replace them at 360 hours.
MILD THUNDER is offline
Old 03-29-2010 | 12:15 PM
Jim Diesel's Avatar
"Unregistered Gun"
Ok, thanks...
Old 03-29-2010 | 12:31 PM
x2
Griff is offline
