stereo electrical noise >
Old 03-31-2010 | 07:19 PM
Default stereo electrical noise
I have electrical noise coming thru speakers. Need some help. A run down of what happened... Last year I repowered in spring and all was good. Had to pull engine late last year for some noise. This was a rush job to make a weekend boat trip.
All was good but the orange wire was left off starter. I didnt realize this until gauge drop to 10 volts. Got back to docks and reattched wire. Ever since I've had terrible noise thru speakers.
I've checked all grounds. Replaced alternator, still there. Removed alternator, still there. Does this when I run anything electrical even with engine off. Hatch, trim tabs, drive trim, doesn't matter. all come thru speakers. Speakers run off an amp, not radio. Could it be radio or amp. What could've gotten fried by not having orange wire connected. Or is a ground issue I'm not seeing. Any thoughts. I'm missing something. Thanks.
steveh1209 is offline
Old 03-31-2010 | 08:52 PM
Sounds like a ground issue. Are you running amplifiers or just using the power from your headunit. If running aftermarket AMPS, I would suggest grounding them straight to the Block. Make sure it is a good bare metal surface, scrap any paint or rust away.
In my Baja I had "noise" when I operated my trim tabs. A new ground to the block solved it.
low_psi is offline
Old 03-31-2010 | 09:09 PM
Running amp. Right now it is grounded directly to battery. I grounded directly to block, made no difference. All my grounds are at the same 2 connection points. Studs on engine bell housing.
Old 03-31-2010 | 09:23 PM
Another thing is that the only electrical connections disconnected to remove engine were main plug and grounds. I always thought that RF noise came from a single item like alternator, bad trim pump motor, etc. Don't understand why I'm getting noise from all electrical components.
Old 04-01-2010 | 06:39 PM
Now I've removed every ground except battery to block and factory wire harness to block. Both have good grounds. with ignition off, radio on, still get noise. Also music cuts out for about 5 seconds. Then when comes back on has music and noise if pump motor or hatch lift running. Radio itself does not cut off. just what comes out speakers Disconnected amp and connected speakers directly to radio. no difference.
Does anybody have any ideas??
Old 04-01-2010 | 08:37 PM
where is the deck itself grounded?
Griswald is offline
Old 04-01-2010 | 09:00 PM
I would take a spare battery and connect power and grounds from the deck and the amps to the new battery. This takes the complete boat wiring out of the equation. If you still have noise then I would guess something with the deck. Something else to try is hook up a speaker to the speaker outs on the deck and see if you have any noise. Do you have high end RCA cables with the seperate ground shield? If so where do you have those connected?
502ss is offline
Old 04-01-2010 | 10:22 PM
Default Fixx
check grounds,,are the amp power and ground going straigh to the battery from the amp? if so then you may have hurt the amp..
FIXX is offline
Old 04-02-2010 | 09:55 AM
So what i found is if I ground head unit directly to block eliminating boat harness. Noise still there. If I add a ground wire from head unit chassis straight to block noise goes away completely. Still shuts off momentarily when running trim or hatch. Something must have happened to head unit. It isn't even a year old never would've thought it was the culprit.
Old 04-02-2010 | 10:02 AM
Ill bet what is happening is that you fried that ground wire coming from the deck internally. It probably burnt one of the traces on the circuit board. What is probably happening is that the deck is now grounding through the shield ground on the rca cables to the amplifier. Then the deck is getting its ground from the amp creating the noise. So you are creating what is called a "ground loop" . You may be able to take the top cover off the deck and see the burnt trace. I would try a different deck or ground it from the chassis like you just did. Hope this helps.
bobsbillets is offline
