Light behind speaker grill >
Old 04-01-2010 | 08:37 PM
Default Light behind speaker grill
On the Hustler website there is a pic of speaker with a biller grille, looks like there is a light behind the grille. Pretty cool, how do you do it?
richanton is offline
Old 04-01-2010 | 08:56 PM
BDiggity's Avatar
led's. u can either buy a kit that has led's in a ring, or just add your own led's to the outer edge of the diaphragm.
BDiggity is offline
Old 04-01-2010 | 10:19 PM
Default fixx
buy the leds off ebay then you hot glue them to the inside of the billit gril..then run the wires to a power sorce..if you want the disco effect then you can wire them to the speaker..
FIXX is offline
Old 04-02-2010 | 06:48 AM
And you just run the wire out from behind the speaker? I need to take a better look; I wasn't sure how to get the wire t the led without seeing it.
Old 04-02-2010 | 11:17 AM
Default Fixx
Back in the day we use to use light bulbs on the + side of the speaker as a cap to keep from blowing them..i never tryed a led yet but im sure it would work..
you will probably need to drill a small hole and run the wires through the out side mounting rim of the speaker..
FIXX is offline
