-   -   Silent choice with surface drives (https://www.offshoreonly.com/forums/general-q/227828-silent-choice-surface-drives.html)
ken sampson 04-06-2010 11:18 AM
I have silent choice with bravos and going to Arneson ASD-8's and want to keep my silent choice. Has anyone seen this type of setup before? I need to know what to do on this one? I'm wondering if I just add a new exhaust pipe under below the water line.
FIXX 04-06-2010 11:47 AM
Fixx
i dont see this happening with the arneson's,their is no way to put the exhaust under the boat,it will act like a water pickup and force water back in..i think your best bet would be air operated mufflers..
redbud35 04-06-2010 09:10 PM
Use turn downs, Kind of get the same effect as silent choice.
rdoactive 04-07-2010 06:50 AM
There's no good way to dump the exhaust under the waterline.
Turndowns will work, are very non-restrictive, but will beloud any time on plane.
You can get switchable mufflers to mount in the engine compartment or on the transom.
Or you could plumb your current system into a can style muffler. But that takes a lot of room in the engine compartment.
ken sampson 04-08-2010 08:25 AM
I have seen something like a can on a Nor-Tech. Anyone have any info on the can type muffles?
rdoactive 04-08-2010 10:19 AM
I think I saw a pic of what you are talking about, but I'm thinking it was designed and built for the Nortech.
Most of the can style mufflers are made for smaller engines and generators. Sea Ray and one or 2 other manufacturers used them with BBC motors, but those are HUGE, and I think were specific for those manufactureres. Do a search, there are several companies (aqualift?) that build them. Maybe they have something that will fit.
Another thought, Formula built something similar into their swim platforms for quieting their exhaust.
