Will these risers work with a bravo >
Old 04-10-2010 | 02:20 PM
Default Will these risers work with a bravo
Can anyone tell me if these risers will work on a bravo set up. Actually I'm going from a 454 alpha to a bravo drive but i think the transom cut outs are in the same location.
endeavour32 is offline
Old 04-10-2010 | 02:37 PM
You will be fine as long as you are running the same engine
Rockfish71 is offline
Old 04-10-2010 | 02:39 PM
These are supposed to be for a transmission set up. So you think these will work with a bravo?
Old 04-10-2010 | 02:41 PM
I thought you where running before the swap it's going to be a coin toss they can be reworked to fit right.
Old 04-10-2010 | 02:42 PM
I really don't know. I would think they can be tweaked but I want to make sure before I buy them.
Old 04-10-2010 | 05:53 PM
Originally Posted by endeavour32
Actually I'm going from a 454 alpha to a bravo drive.
I'm not sure about the risers, But just be aware that you will need a new bravo style Thermostat housing or your engine will over heat at idle, If you do not change it out from the alpha thermostat housing.
Boat Tech is offline
Old 04-11-2010 | 09:59 AM
Smitty's Avatar
They look a little long for a non-transmission equipped boat.
Smitty is offline
