engine cuts out momentarily when hitting hard waves...
1 Post
Just as the title says, engine is cutting out when hitting waves hard. I've checked all power and ground connectiions, all ignition wiring and kill switch...
Got any ideas?
1994 baja 272 with carb hp500
Got any ideas?
Thansk
Steve
Coils are cheap. Just get a new one. You really cannot test them in real world conditions.
Personally I would double check all connections in the path for the ignition. Another slight possibility is the float level in the carb is not perfect and when you jar the boat, you might be causing a momentary lack of fuel or a shot of too much.
1 Post
Thanks guys, I will innstall a new coil, this one looks OE, so its worth the change annyways. I will check out the other parts of the system, and the breaker nut.
What coiil should I replace with OE merc or other?
You double checked the large engine wiring harness plug with the hose clamp on it? Seen those come loose and do same as yours is.
I had the same problem with the Nova When I first got it. The Port motor would cut in and out bad in higher seas. I finally got so pissed one day I punched the dash with my fist in the channel and it did it again. Turns out the ignition switch was bad. But on the trailer in the driveway it worked perfect.
