-   -   water sensor with crossover ?? (https://www.offshoreonly.com/forums/general-q/228658-water-sensor-crossover.html)
rssteiny 04-19-2010 07:27 AM
1 Attachment(s)
Im changing to crossovers w/ bypass, as you see in the picture i have a water temp sensor (im guessing) in my stock t/ stat housing, and dont see anywhere to put it with the crossover.
hoozeyurdaddy 04-19-2010 08:42 AM
there should be a plug in the intake manifold you can remove and install it there.
rssteiny 04-19-2010 02:18 PM
1 Attachment(s)
only 1 in intake already has a sensor in it.
ezstriper 04-20-2010 06:29 AM
my aftermarket therm housing has a spot where I put mine...
rssteiny 04-20-2010 07:26 AM
yea mine does not, i guess i could have it drilled and taped to fit the sensor.
JohnSchiavarelli 04-20-2010 07:30 AM
try hardin marine.. they make a 1 inch spacer that can fit 2 sensors in them.. I have it now.. works fine
rssteiny 04-20-2010 07:41 AM
Found it thanks
FIXX 04-20-2010 09:44 AM
Fixx
Drill and tap the ss thermostat housing for a sensor..
rssteiny 04-20-2010 01:28 PM
Where at in the top of it i would guess.
FIXX 04-20-2010 01:47 PM
Fixx
i would rather see it before the thermostat like stated in the intake manifold but if their is no other option then i would work their..
