500 hp carb set up >
500 hp carb set up
500 hp carb set up
Old 04-23-2010 | 10:58 AM
Default 500 hp carb set up
ok finishing my 500hp, +.030, factory cam, intake, but has stainless marine full headers, doing up a 800 DP, just cause I have one, milling the airhorn, where's a good place to start jetting wise on this setup...Thanks Rob...also how much total timing to run on 87 at times..
ezstriper is offline
Old 04-26-2010 | 05:59 AM
ttt
Old 04-26-2010 | 08:12 AM
blue thunder's Avatar
77p - 92s with a 4.5pv in the primary. This assumes air bleeds are fixed and original. You could also get the hp500 specs and do the staggered jetting.
34 degrees timing all in.
blue thunder is offline
Old 04-26-2010 | 12:58 PM
Holley 800cfm HP500 stock jetting is:
Primary - Port 81, Stbd 75
Secondary - Port 89, Stbd 93
6.5 PV in the front. The secondaries don't have a PV.
If I was rejetting, I would probably just use 77 primary jets and 91 secondary jets.
Griff is offline
Old 04-27-2010 | 06:22 AM
thanks guys, just what I needed...and just getting ready to put carb together !! Rob
Old 04-27-2010 | 07:31 AM
http://www.mercruiserparts.com/Show_...OR+AND+LINKAGE here mec setup
bajabob is offline
