454 --> 496 Build Check >
Old 04-29-2010 | 01:44 AM
I would just get a stroker rotating assembly then.
Griff is offline
Old 04-29-2010 | 08:19 PM
Default 496
Originally Posted by jeffswav
Ok, you are on the right track so far. Have RMbuilder custom grind you a cam and prop it for 54-5500 RPM. Call him first before you buy any more parts. Do a search and you will find a lot of guys here use him. He can easily get 500HP out of a 496 stroker. I use the EMI exhaust, there a other good ones out there. Be sure to get long risers and do not try to use silent choice with the bigger cam. Get a big 3" oil cooler the one that came stock is to small. Be sure to upgrade the oiling system with bigger lines and less restrictive fittings. Be sure you get the 30psi diferential valve in the oil pad. Good luck with your build.
Would it be considered safe to run Eagle 4.25 cranks at that RPM? And what about going to a 4.375 for adding cubes
redcorvetteman3 is offline
