Bad Lifters -  Now what? >
Old 04-30-2010 | 11:09 AM
Default Bad Lifters - Now what?
Definitely have some bad lifters, now what:
At least 4 of them are bad. Thinking I should just go ahead and replace them all. Does that make sense? Should I replace pushrods too?
olysan is offline
Old 04-30-2010 | 11:37 AM
Roller or flat tappet??????? What is wrong with them and what caused it???
You should definately replace all the lifters. If the pushrods are straight and the ends are good, I see no reason to replace them.
Griff is offline
Old 04-30-2010 | 11:49 AM
Ted G's Avatar
Roll the pushrods on a flat piece of glass, if they roll quietly they are straight. If they make a tap noise they are bent. I am also curious as to what's wrong with the lifters. If they are bad, check each cam lobe carefully for damage also, use a flashlight through the lifter bore.
www.cbpba.com
Ted G is offline
Old 04-30-2010 | 11:50 AM
Like Griff said, replace all of them. Are you pretty certain it's your lifters? Unless your running an agressive valvetrain, no reason to replace the push rods unless you find something wrong with them.
getrdunn is offline
