496 ho.s run very rich >
Old 05-03-2010 | 05:02 PM
Default 496 ho.s run very rich
new boat to me 03 formula 312 w 496 ho.s motors turn 5000 all stock 160 hrs motors seem to run excellent . i removed the silent thunder platform an installed straight tips . problem is back of boat is all black from exhaust i think their was a recall at 1 time reguarding this anyone have any ideas or suggestions . i dont think their is any problems w motors just rich running
smokin' gun is offline
Old 05-03-2010 | 05:11 PM
t500hps's Avatar
21 and 42 footers
If desired, you could add the CMI exhaust that supposedly adds 50-60hp which would help "lean" the motor out too. (sounds like a win/win)
t500hps is offline
Old 05-03-2010 | 05:13 PM
I think this is fairly normal. Everyone ive seen leaves black on the back of the transom. I guess it just depends on how much you are talking about.
soonenough is offline
Old 05-03-2010 | 05:15 PM
"supposedly" being the key word
Old 05-03-2010 | 05:59 PM
30 outlaw 2005's Avatar
Cured my black transom problem...
30 outlaw 2005 is offline
Old 05-04-2010 | 05:53 AM
Dave M's Avatar
Veteran: Navy
For some reason, I usually only notice exhaust soot when the water is cold.
Dave M is offline
Old 05-04-2010 | 09:42 AM
Plum_Crazy's Avatar
I ran into this issue when I purchased my '03 Sonic. The transom would be completely black after just an hour of use. It was sticky and tough to remove. There was a recall on the ECU's in 2003 that was never performed on my boat. It has something to do with incorrect voltages to the fuel injectors. I worked with Mark at Precision Marine(pmefi.com) to get the updated program. Now, I only get a light film that easily washes off.
Plum_Crazy is offline
Old 05-04-2010 | 12:02 PM
It helped with mine too. I was commenting on the 50-60hp increase claim.
Old 05-04-2010 | 12:35 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Run your ECU S/Ns through your closest Mercury dealer. You will can either get a reprogram or new ECUs, depending on the models.
Sydwayz is offline
