Raw water pump mercruiser 7.4 >
Old 05-06-2010 | 01:54 AM
Default Raw water pump mercruiser 7.4
have a 1988 chaparral villian3 with a 7.4 mercruiser. My raw water pump needs replacing, I purchased one off e-bay and was sent the one for a serp belt and not the v-belt like is currently on it. Anyway to change pulleys, or convert this to work?
kwtv38 is offline
Old 05-06-2010 | 06:10 AM
kwtv38,
If you swap out the pullys, I am interested in the serp belt pulley for the waterpump.
Ken
minxguy is offline
Old 05-06-2010 | 06:44 AM
Ken if I can get the pulleys swapped will let you know. The problem I'm having is the vbelt pulley has 4bolts and the serp one looks pressed on.
kwtv38 is offline
Old 05-06-2010 | 07:18 AM
Kw, why didn't you just rebuild you old pump?
wjb21ndtown is offline
Old 05-06-2010 | 07:38 AM
try this place http://www.boatbandit.com/262~marine...:drink::drink:
bajabob is offline
Old 05-06-2010 | 08:24 AM
hoozeyurdaddy's Avatar
the fitting on the old pump with the bolt holes will press off also, and then you should be able to press it on the new pump.
hoozeyurdaddy is offline
Old 07-03-2010 | 12:23 AM
mcollinstn's Avatar
How much do you want for your old pump?
MC
(you can PM me)
mcollinstn is offline
