Ramco Fuel Filters >
Ramco Fuel Filters
Ramco Fuel Filters
Old 05-09-2010 | 08:07 PM
CcanDo's Avatar
Default Ramco Fuel Filters
Has anyone used the Ramco fuel filter with a filter head supplied by others ?
www.ramcoperformance.com
CcanDo is offline
Old 05-09-2010 | 08:21 PM
This is what I use and would buy again
http://www.eddiemarine.com/store/car...l&p=12177&c=42
Rockfish71 is offline
Old 05-09-2010 | 09:30 PM
CcanDo's Avatar
Thanks .....Eddie has good products....The filter your using is stated to be 100 GPH. Whereas, the rule of thumb is: size the filter to twice the known dyno draw or consumption.
At WOT we can use fuel at the rate of 560#/hr or a rounded number of 100 GPH. Therefore, using the rule of thumb, the filter should flow at least 200 GPH.
CcanDo is offline
Old 05-09-2010 | 10:26 PM
Wink
We have used the Ramco fuel filter on a few engines and have had excellent results. They are very fuel filter knowledgeable, make a fine product and many variations depending on needs and usage.
Best Regards,
Ray @ Raylar
Raylar is offline
Old 05-10-2010 | 07:35 AM
CcanDo's Avatar
Best Regards,
Ray @ Raylar
Thanks Ray, Have you found the Ramco filter fit any of the other brand filter heads ?
Thanks !
CcanDo is offline
