spark plugs
Old 05-09-2010 | 11:12 PM
Default spark plugs
could someone help me with spark plugs mercruiser 1998 502 mag ac mr43t is the rapidfire #10 a replacement plug for the mr43t. and or able to run in this motor
mirage is offline
Old 05-10-2010 | 01:18 AM
You can run a Rapid Fire #1. It is the same heat range as an MR43T, but has a slightly extended tip and is a direct replacement for the R43TS. I'm not sure if the #10 is direct cross with the R43T.
In reality though, you will not gain a thing by running them over the stock MR43T. You could just run an auto motive R43T or R43TS.
Griff is offline
Old 05-10-2010 | 02:16 AM
Ive heard that spending the outrageous money on plus liks platinum, split fire etc is a waste and actually isnt good. I have the new camaro and the book says do not use anything but a regular copper top. I mean if you have some big custom engine than sure. But if you have the relative basic 454 502 stick with the stock
nards444 is offline
Old 05-10-2010 | 10:13 AM
Ngkbpr6fs
Pismo10 is offline
Old 05-10-2010 | 04:32 PM
Why not just run the MR43T? Nothing to be gained with fancy spark plugs.
cubicinches is offline
Old 05-10-2010 | 05:30 PM
As far as I know, all Mercruisers today that are fuel injected, ship with platinum spark plugs.
http://www.mercurymarine.com/engines.../mpi8-2lho.php
All the way to the 8.2 Mag. I don't know about Mercury Racing, I assume they'd be specced that way or higher for plugs. I also noticed that the carb motors have a 45 gap, the plats are at 60.
VtSteve is offline
Old 05-11-2010 | 02:07 AM
Carb engines gap at .035. The first platinum plugs Merc used were in the 496's. Before that they ran the NGK BPR6FS's and the MR43T's.
Griff is offline
