Gimble Bearing Help!!!!!!! >
Old 04-30-2002 | 02:04 PM
Raypanic's Avatar
Thumbs up
Well I got the gimble bearings in sucessfully, excaleagle42 I tried your freezer trick, I believe it helped quite a bit. I used the merc tool to pull them and the merc driver to install them. I cannot see someone using a slide hamer to pull them out they were in there very tight. The puller tool uses a big threded rod and a nut to pull them out . I really had to reef on the wrench. They were original to the drive as I could tell from the marks in the housing. I am glad I replaced them. One was definatly bad
One drive lines up perfect the otherone needs the engine adjusted
Thanks to all
Ray
Raypanic is offline
Old 05-01-2002 | 01:23 AM
Hot Boat's Avatar
Team Dysfunctional
I would try leaving the bearing in a freezer for a while or over night. if you could heat the gimbol housing with a heat gun just prior to installation it would help to. I done this before with other bearing on car axels and it works with great results. They practically place right in. good luck
Hot Boat is offline
awesomecat26
Drives and Lower Units
3
08-13-2007 11:28 AM
rush
10
07-28-2006 07:30 PM
Elite Marine
1
07-12-2004 06:33 AM
ragtop409
6
09-08-2003 09:30 AM
Raven
2
06-02-2003 08:17 PM
