-   -   Alpha Trim Hose Replacement (https://www.offshoreonly.com/forums/general-q/23043-alpha-trim-hose-replacement.html)
klmken 04-25-2002 10:15 PM
How does one go about replacing one of the hoses that runs from the trim pump to the transom assembly? I can undo the leaky hose at the trim pump but have no idea where it attaches in the transom assembly?? Merc manual doesn't say!!
Thanks,
Ken
Tinkerer 04-25-2002 10:41 PM
EASY -- Just remove the bolts holding the plate that the hoses conect to under the drive - next to the transom
FloridianSon 04-26-2002 06:45 PM
Don't use any thing but line wrenches on the hoses!
doug hess 04-26-2002 08:14 PM
Before you try standing on your head in the bildge use the easy way outside where the trim cylinder hoses attach to the manifold block. Remove the two 1/4-20 NC bolts. Pull down the block. The hoses from the pump attach to the inside of that block.
Doug
