Use big cam and big heads or procharger >
Old 05-22-2010 | 06:07 PM
Originally Posted by GPM
4.25 x 3.76
4.31 x 3.76
endeavour32 is offline
Old 05-22-2010 | 06:28 PM
GPM
Originally Posted by endeavour32
4.31 x 3.76
4.31 x 4.31 x 3.76 x .7854 x 8 = 438.8
GPM is offline
Old 05-23-2010 | 11:10 AM
Default how to contact rmbuilder
Can someone tell me a website or ph# for rmbuilder?
thanks!
B.O.T.E BBC427 is offline
Old 05-23-2010 | 02:09 PM
Default Fixx
thanks!
Bob 585-654-8553,, CAM AND PROCHARGER..
FIXX is offline
Old 05-25-2010 | 07:00 PM
What is your HP and speed goal. I would see if a 4.25" crank could be used in your block. That would give you more torqe and HP. If you call Bob he would probably know. Definatly get your cam and matching parts from him.
jeffswav is offline
Old 05-25-2010 | 08:35 PM
60 over 427 makes for real thin cylinder walls ! I used to run that combination years a go in my drag car, split lot's of cylinder walls . Not a good set up for a boat or a drag car !!!
Jeff P31 is offline
Old 05-26-2010 | 06:07 PM
Default watch the cam
The procharger will give you excellent torque and hp throughout the rpm range but make sure you put in a roller cam. I had years of misery burning up two 454's with only roller rockers.I dont care what Procharger says you will burn up cams,lifters and pushrods even at 4lbs boost.
TWO YOOTS is offline
