Best oil for 502 MPI? >
Old 05-19-2010 | 03:33 PM
Default Best oil for 502 MPI?
Suggestions/opinions/advice?
Service manager at our marina recommended a straight 40 weight oil since the 502 tend to burn a little oil. Anyone have any experience with this idea?
Thanks,
Russ
Russ13100 is offline
Old 05-19-2010 | 03:45 PM
Mobil 1 vtwin 20w50 is excellent doesn't really break down. Or vr1 20w 50 or staight 50 if ur clearences are getting loose and oil pressure a tad low. Both are available at a good parts store.
GTOFFSHORE is offline
Old 05-19-2010 | 04:18 PM
Thanks,
Russ
I built a lab for a company that grades all the oils to the fed Stds. Way cool place if you like blowing **** up..(motors etc) When I asked what was the best oil.. He could'nt answer that.
Legal thing I guess.. But once I re-asked the question. What does he use. He said the only oil he will ever use is Valvolene 20-50 racing oil.. Let it be written let it be done
silent lucidity is offline
Old 05-19-2010 | 05:43 PM
Mobil 1 15-50 cut my oil consumption in half on my 502mpi's.
Griff is offline
Old 05-19-2010 | 07:14 PM
My 502mpi used a half a quart of oil everytime I took it out. Switched to 40w Rotella and never added a drop all last season. Jeff Wurl
jwurl is offline
Old 05-19-2010 | 07:23 PM
R Addiction's Avatar
AT Cult Member #3
Good thread. I've always used Mercury 25w40 and mercruiser filters. 500hrs and runs great. Does use a bit of oil though. Always have.
R Addiction is offline
Old 05-19-2010 | 09:27 PM
But, was he referring to the off road only VR1 Racing OR the SM (lower ZDDP)rated VR1 Racing oil. Or could it be the Synthetic VR1 Racing oil?
HammerDown is offline
Old 05-20-2010 | 05:49 AM
Thanks for the responses!
My 502 was totally rebuilt less than 50 hours ago and i've only owned it since last sept. which means ive only been out with it 5 times so I haven't been able to get a steady read on its oil consumption habits.
Old 05-21-2010 | 07:15 PM
Hydrocruiser's Avatar
Arrow
These engines can sludge up quickly.
M-1 V-Twin won't break down under extreme heat and won't shear down either. You need both.
Amsoil 20W-50 V-Twin/Redline 20W-50 motorcycle oil/Royal Purple Motorcycle oil...are also very beefy and great choices.
M-1 15W-50 is now an SM oil with too little ZDDP for Offshore Engines.
Never use an SM rated oil.
Oil filter? Merc HP/Wix/Baldwin/K&N/NAPA Gold.
This is for any and all big blocks. Period.
Tried and true.
Hydrocruiser is offline
Old 05-21-2010 | 10:09 PM
What is an SM oil?????
Griff is offline
