Steering Question
Hi All,
I have a multi part question. I am having an issue with my boat pulling hard to the left while accelerating and the diving right when I back off the throttle. First question is how muck play if any is allowed where the clevis pin form the steering cables hook on to the arm that pushes-pulls the drive? Also if I was to run it on the hose in the driveway should the Power steering pump hold things firm or would there be a give due to being at idle. There is no real plat in the gimbal up and down or left to right. Thees is a bit of slop in the cabling Also could this be a prop issue? Any help would be appreciated I think I have a bad power steering pump but not sure |
Originally Posted by the vig
(Post 3116729)
Also if I was to run it on the hose in the driveway should the Power steering pump hold things firm or would there be a give due to being at idle. #2 Could be the steering ram behind the motor. I had that issue before switching to full hydraulic steering. When I pushed the drive, I could hear air escaping from the PS reservoir. |
1990 boat im going with the gimbal ring.
Where are you in Chicago? |
I am up near Winthrop Harbor.
I had George form Performance Products go through the drive before it was installed las year he checked the gimbal bearing and thought it was fine. How can I check? |
(Post 3118402)
How would I be able to tell if there is a problem with the gimbal itself?
Is there anything I could check? |
(Post 3118997)
| All times are GMT -5. The time now is 09:29 PM. |
