Merc 500HP "Blue Motor" Cam & Heads >
Old 05-22-2010 | 08:07 AM
Registered User
Default Merc 500HP "Blue Motor" Cam & Heads
Okay
I have a 1998 Eliminator XP Eagle with the 502 HP 500 Carb'd "Blue Motor" and I am getting ready to change the head springs as recommended through my research on this site.
Digging deeper into the cam specs here at OSO I have run into a conflict of information that I need to clear up and then talk about some mild head work.
My research shows that the correct cam specs for this model motor is the Crane #169611 - However SB posted on here in 2006 a statement that has me a bit confused. quote as follows;
"The HP500 (blue carb'd motor )used the HR '721' grind from Crane. Gen V and Gen VI motors. Just different cam cores."
The only match in the 721 grind is the Crane # 168721... So which one is correct??? the #169611 or the #168721
The other side of my seeking advice is that I have decided to go ahead and recondition the heads and have some mild porting and bowl work done. I was planning on sticking with the stock cam and carb and just clean up the heads.
I have read that some recommend having the exhaust relieved as well because the intake is so much larger. Is this a good idea??
Any advice on anything else I should consider??
Oh, and any recommendations for head springs, obviously looking for more durability but do not want to break the budget.
Thanks in advance... John
XPeliminator is offline
Old 05-22-2010 | 11:27 AM
The Crane 169611 is the carbed HP500 cam.
Valve Spring options
Comp Cams 929
Isky 8205-SP
Griff is offline
Old 05-23-2010 | 07:45 AM
Registered User
Thanks for your help
