??? Blown bravo one drive >
Old 05-23-2010 | 09:47 PM
Default ??? Blown bravo one drive
I was cruising along 3/4 throttle when my outdrive started rattaling, and the rpms reved up. Then was unable to put it into forward or reverse? what do you think happened?
B_Schutz is offline
Old 05-23-2010 | 11:22 PM
sounds like a couple of mine that let go. Pull the plugs and top cap to inspect. If there's metal everywhere you're done. You really can't speculate without looking..
Sorry to hear. I have a nice used drive if you wind up needing one (hopefully not).
SDFever is offline
Old 05-24-2010 | 01:10 AM
Upper gears are toast.
Griff is offline
Old 05-24-2010 | 05:54 AM
Im heading out to the shop now to pull of the drive. If the upper gears are crashed where is the best place to get a repacement. I want to plan on my future 600hp and external steering.
B_Schutz is offline
Old 05-24-2010 | 08:48 AM
i have 2 fresh rebuilt drives,2000. each,will seperate,i am in yorkville,illinois.
mike tkach is offline
Old 05-24-2010 | 09:37 AM
The upper bevel gears are done, so what should I repace it with in anticipation of external steering and 600hp
B_Schutz is offline
Old 05-24-2010 | 09:52 AM
If you dont end up buying new, or slightly used- the closest super competent rebuild guy to you in Ill is probably Dick ( I think his last name is Trice) known as Mr. Gadgets. I think hes in Michigan. You can look up Arcticfriends as well.
Thing is the victory is a really heavy 27 ft boat, one of the biggest 27's out there (the best 27 weekender I have ever been in) and its really hard drives.
You can get a few better parts form teague or imco and have Gadgets put them in for you. Youll need someone to tell you if your cases are any good or not- this last shot may have wiped them out.
Did you have any shavings on the last oil change?
Uncle Dave
Uncle Dave is offline
Old 05-24-2010 | 09:59 AM
No the oil on this drive has always been clean, I dont know how expensive a rebuild is, but I just figured I would get a new one with a warranty?
B_Schutz is offline
Old 05-24-2010 | 10:07 AM
Depends on if the lower needs one as well.
For an upper and lower rebuild with ALL new parts and a thorough cleaning I think you are looking at around 5K for both.
what did the lower magnets look like?
How many hours on your rig?
Uncle Dave
Old 05-24-2010 | 10:14 AM
BTW- I dont think anyone warranties a drive only- I think a warranty comes with a NEW engine packages only, but I could be wrong.
UD
